Over the weekend I plumbed in my ballast bags and ran into a problem. Filling the bags everything works great but as soon as I go to drain the bags I can’t get the drain pump to prime.
I connected everything so I would only have one line on each bag and be able to fill/drain each bag with the turn of a couple ball valves.
The ballast bags are both located above the pumps so I wouldn’t think they would have a problem priming with the help of gravity.
The pumps are Attwood 800gph and are mounted horizontally with the outputs facing about 45* down. Is the angle of the outputs causing the priming issue or am I missing something? I haven’t had a chance to adjust the pumps to angle the outputs up and see if this will fix the problem.
I attached a diagram of how I have the bags plumbed. Any input would be appreciated.
