Rust in Port Manifold of 1999 SNOB GT-40
  • todda
    • Jan 2005
    • 281
    • Granite Falls, WA
    • 1999 SNOB
    Upon winterizing our boat tonight, I noticed (what seems to be) an unusual amount of rust coming out of the port side manifold of our GT-40. In years past, I have noticed more rust-colored water, but never have noticed much for small pieces of rust coming out with the water as I did tonight. Anyone else have this issue? Is it a problem that I need to have checked any further? Thanks for any input!
    Todd
    Todd Aalbu
    1999 SNOB
    66.5" HO S2
  • hyparks
    • Feb 2011
    • 302
    • Brownhills, United Kingdom
    • 2001 Super Air 210
    How good do you winterize? Do you fill with antifreeze or just empty the water? Usually rust is caused by water being drained and air getting into the system e.g if you take your pump off then sir can get into the engine via the open pump pipes etc. This will then cause build up of rust which after use will then come away. I have had the same issue with my 01 san gt40.
    Hope this helps
    Current
    2001 SAN 210, GT40
    Previous
    1994 Mastercraft Pro Star 190
    • todda
      • Jan 2005
      • 281
      • Granite Falls, WA
      • 1999 SNOB
      Hyparks, thanks for the input. Yeah, in the past, I have only drained the water without using antifreeze as I have a heated/insulated garage that doesn't drop below 50 deg. I figured it would be better to drain the water, rather than let the water sit in the engine block and manifolds for the off-season. Would I be better off keeping the water in the engine, or just suck in the antifreeze regardless just for the anti-corosion effect? I would rather not use the antifreeze if I can get away from it just from the pure PITA factor. Thanks again for the response.
      Todd Aalbu
      1999 SNOB
      66.5" HO S2
      • hyparks
        • Feb 2011
        • 302
        I have done the antifreeze this year. I owned my old mastercraft for around 5 years and only ever drained the water with no problems. It's a choice only you can make I'm afraid.
        Good luck
        Current
        2001 SAN 210, GT40
        Previous
