Where is the OEM factory harness for the shower switch
  • ers906
    • Feb 2010
    • 921
    • Phoenix AZ
    Anyone know where the wiring harness controlled by the shower button on the control pad of a 2002 super air nautique is/color of the wires etc? I have placed a hot water shower in the V-drive compartment my SAN, but cannot find the wiring to control the pump (gerry rigged a switch for the time being). Would appreciate any help, and or pictures as well. Thanks, Eric
    Eric, Phoenix AZ
    G23 550 hp (finally here)
    2002 Super Air
    look on the starboard side, below the engine, on the stringer. You are looking for a connector, with just a short loop of wire, with a lump in the loop. I am going to go out on a limb, and suggest the wire is colored orange, or has a orange stripe. It is paired with a black wire, that goes to ground.
    • ers906
      • Feb 2010
      • 921
      • Phoenix AZ
      So just to clarify, the harness should have the typical grey or black plug (I think that is what you meant by connector) at the end, with an orange (or orange striped) wire and black ground, located on the STBD side of the stringer under the engine block.
      Eric, Phoenix AZ
      2002 Super Air
      • ers906
        • Feb 2010
        • 921
        • Phoenix AZ
        For future reference (if anyone is using the search function) the wiring harness for the 2002 super air shower is a orange with black stripe wire (with black ground) that is behind the kick panel of the dash.
        Eric, Phoenix AZ
        2002 Super Air
          Was the wire coiled up behind the kick panel? Sometimes they ran the wires back into the engine compartment, other times they did not.
          I think it was around 2002, or 2003 Correct Craft quit offering the shower as a factory option. It was decided since most of the time people ran the engine to keep constant supply of hot water, anf the shower was used on the platform, it created a hazardous situation with carbon monoxide from engine exhaust, and the possible hazards of a spinning prop from somebody falling off the platform with the engine running.
