Looking for some help. I have a PCM GT-40 (99 SAN) and am installing a closed cooling (half) system. I believe I have everything laid out correctly, but I am looking to make a little modification (If possible)... Two questions:
1. Does coolant always circulate and what happens to flow when the thermostat opens/closes.
2. The transmission cooler and v-drive are raw water cooled. How much heat do they generate and can I add them to the closed cooling system? If so, how?
*I was thinking of adding two Ts, exit from the circulation pump and re-enter from the far side of the heat exchanger (at the downpipe from the expansion tank.) Would this provide enough circulation?
Heat exchanger is dual pass.
