Installing a Shower in a SN200
  • Sullivan
    • Jan 2010
    • 109
    • Mint Lake
    • 2013 Team 200 CB Promo Masters Blue/Metal Flake Black
    Anyone done this yet? I'm planning on putting the temperature control valves in the engine compartment and then coiling the hose and shower head in the passinger side ski locker. Any suggestions or pics of your install would be greatly appreciated.
    Nautique Promo Team Washington/Oregon
  • ers906
    • Feb 2010
    • 921
    • Phoenix AZ
    I just installed the shower last week, I can post some pictures early in the week. Do you want pictures of where the lines (hot, cold) attach to the block? the wiring? etc? If you have the factory switch and cannot the harness look under the console, there are bundles of wires coming out of the fuse box that are not being used. I hooked a voltmeter up to every spare harness I could find, and kept testing until I found the one that corresponded with the factory switch. It turned out to be a two wire harness with a black ground and and orange/black stripe power. I am told in some boats they ran the harness back to the engine block and it is located under the engine, on the starboard side along the stringer. I found orange wires back in that area, but after tracing all the wiring diagrams, it seems that those were for a model/option for a power seat (?). Anyway, it took me longer to find the harness then it did to set up the remainder of the shower. Anyway, let me know what pics u need.
    Eric, Phoenix AZ
    G23 550 hp (finally here)
    2002 Super Air
