Per Gary at PCM...pulling lanyard will not turn off fuel and spark, and fogging unnecessary unless storing over a year....
To: scott@.com
Subject: RE:WEBSITE SUBMISSION
Date: Tue, 4Dec 2012 13:53:47 -0500
Scott,
the only wayto kill both spark and fuel effectively is to put the engine in a compressiontest mode. This has to be done with Diacom which is something that our dealerscarry. Otherwise unless you are storing the boat for an extended time (likeover a year) then you don't really need to fog the engine.
Gary Galat
CustomerService
PleasurecraftEngine Group
ph(803)345-1337 ext114
fax(803)345-3309
-----OriginalMessage-----
Sent:Friday, November 23, 2012 11:52 AM
To: GaryGalat
Gary, Ithink I responded some time ago that it is not a catalyst engine. Did you ever figure out if there is a way toturn motor without squirting fuel?
To: scott@.com
Date: Fri, 2Nov 2012 16:07:48 -0400
Scott, Ineed to know if this is a catalyst engine.
Gary Galat
CustomerService
fax(803)345-3309
Sent:Thursday, November 01, 2012 5:50 PM
To:GaryGalat
sorry it isexcalibur 343...i can get engine serial number if you need it. but i suspecdt you dont need for thisparticular question.
To: scott@.com
Date: Thu, 1Nov 2012 16:45:23 -0400
Scott,
Which enginedo you have, is it the catalyst?
Can youprovide the engine serial number?
Thanks,
Gary Galat
CustomerService
fax(803)345-3309
Sent:Tuesday, October 30, 2012 7:57 PM
To:ggalat@pleasurecraft.com
Subject:WEBSITE SUBMISSION
WEBSITESUBMISSION
manual saysafter fogging to turn over engine few time by hand via crankshaft. i amwondering if there is a way to easily use starter to do this but not squirtfuel to dilute the fogging oil. will pulling the lanyard stop fuel and / orspark?
the issuefor me is that i like to fog each cylinder and then put spark plug and bootback on to not mix up...then i can't turn engine with crankshaft bolt.
To: scott@.com
Scott,
Gary Galat
CustomerService
fax(803)345-3309
To: GaryGalat
To: scott@.com
Gary Galat
CustomerService
fax(803)345-3309
To:GaryGalat
To: scott@.com
Scott,
Thanks,
Gary Galat
CustomerService
fax(803)345-3309
WEBSITESUBMISSION
