boat not wanting to start: low voltage...
  • Mamigacz
    • Oct 2012
    • 118
    • Sheboygan Falls, WI
    • 1986 Ski Centurion concourse skier
    Wonderful!
    • bhectus
      • Sep 2010
      • 283
      • Gainesville, FL
      • '02 Ski Nautique '87 Barefoot Nautique - sold '97 Super Sport - sold '96 SN196-sold '83 2001 sold
      You need to put some new ground cables in if they were corroded. Corroded cables will have a ton of voltage drop. That is your problem.
      2002 Ski Nautique 5.7 GM Apex
      • gride
        • Jun 2007
        • 1441
        • War Eagle
        • 05' 210 team
        I'll do that. Should I use some nice stinger 2ga or just normal battery cable? I'll go ahead and replace the power & ground. I know the grounds have been in since at least 08 if not factory equipped. I replaced the power this year, but I might re do it anyway bc I like soldering battery terminals. Merry Christmas nautiquers.
        • bhectus
          • Sep 2010
          • 283
          • Gainesville, FL
          You need to get marine rated power and ground cables. Tinned copper with crimp-on style connectors. DO NOT go to the auto parts store and get anything there. You'll only be dealing with the same issue in the near future.
          Check this link out, these are what you need. They have 8 foot pre-made cables for pretty cheap. Just click on the drop-down box for different lengths.
          http://www.jamestowndistributors.com...Battery+Cables
          • gride
            • Jun 2007
            • 1441
            • War Eagle
            • 05' 210 team
            there's nothing different about that cable. soldered terminals and some heat shrink. i'm going to use whatever they sell at the deka store.
            • bhectus
              • Sep 2010
              • 283
              • Gainesville, FL
              #21
              Here it is again since you seemed to miss it the first time. "You need to get marine rated power and ground cables. Tinned copper " It is most certainly not the same as automotive cables.
              • gride
                • Jun 2007
                • 1441
                • War Eagle
                • 05' 210 team
                #22
                Thanks. I didn't see any mention of marine anything when I clicked the link. Given need for that, shouldn't my stereo stuff be that also rather than stinger ofc?
                • TX-Foilhead
                  • Mar 2009
                  • 351
                  • Kingsland TX
                  #23
                  A lot of the stereo wire is tinned, if yours isn't look at New Konceptz just don't get the cheap CCA wire. Genuine Dealz also has alot of the standard tinned wire at reasonable prices if there is such a thing, and they put it together for you if you know exactly what you need. Normally I would say if you solder and shrink wrap everything it should be OK, but if your in brackish water then the tinned wire will last longer.
                  • Mamigacz
                    • Oct 2012
                    • 118
                    #24
                    Sorry, I'm curious. Did the new starter fix your issue? With all the talk about ground cables, I was starting to think your starting issue still exists. Or was the suggestion to go with new ground cables a preventative measure for the future?
                    • gride
                      • Jun 2007
                      • 1441
                      • War Eagle
                      • 05' 210 team
                      #25
                      Well the parts are not here yet. I'd imagine tomorrow or Thursday(should have paid the $1.00 extra for ups ground) my shop is closed all friggin week. I'll let y'all know what happens with the new starter jan. 2. The old one is already out so...if for some reason it was just bad grounds ill save the old one for a quck fix if needed. After we do that I'm going to replace the ground cables anyways with tinned copper as suggested.
                      • bhectus
                        • Sep 2010
                        • 283
                        • Gainesville, FL
                        #26
                        gride, I would hate to see you spend all that money on a new starter if it isn't needed. Your symptoms of low voltage and you saying the ground cable's corroded is telling me that the problem is in the cable. That is a tell-tale sign. I would replace the cable first and see if that remedies your issue, then you could probably return that starter and get your money back to buy some tequila for the ladies. It does great things on boats out in the toasty sunshine.
                        • gride
                          • Jun 2007
                          • 1441
                          • War Eagle
                          • 05' 210 team
                          #27
                          i got the parts in today. i'll be going in on jan. 2. i'll have them put in some new TINNED copper cables with solder/heat shrink and see if that works, but i think they tested the starter and it wasn't working. i'll definitely let ya'll know what the REAL cause of the problem turns out to be. and since i got the parts myself i know my shop(who i trust anyway) isn't trying to just make money on parts and extra labor. Patron for sure. cuervo gold if youre feeling cheap.
                          • gride
                            • Jun 2007
                            • 1441
                            • War Eagle
                            • 05' 210 team
                            #28
                            She's real perrty though ain't she.
                            • xrichard
                              • Aug 2008
                              • 669
                              • El Dorado Hills
                              • 2023 G23
                              #29
                              FWIW, the ABYC specifies that solder is not to be the sole form of mechanical connection in a circuit. The reason is that the vibration/flexing in a boat can cause the solder to fail, allowing (a potentially hot) wire to come loose from the connector. You should really crimp. Genuinedealz will make up custom-length crimped cables to your specs--reasonable prices and (from what I can tell) good quality. I've also been to West Marine stores where they have crimpers available for customer use...so, if you buy your connector there you can probably use their crimper.
                              Previous boats:
                              2015 G23
                              2008 SAN 210
                              2002 XStar
                              1995 Sport Nautique
                              • gride
                                • Jun 2007
                                • 1441
                                • War Eagle
                                • 05' 210 team
                                #30
                                i've got a hammer crimper(which i hate). my soldered and heat shrunk terminals i have right now are crazy strong.
