For those interested in oil, good reading here:
http://www.bobistheoilguy.com/motor-oil-101/
and on viscosity:
http://www.bobistheoilguy.com/puttin...nto-viscosity/
One question I have, wrt marine use, is operating temperature. Because of the unlimited supply of cooling water, we know our motors run cooler than cars when measured at the thermostat. But I'm guessing, because of the high loads and high RPM, we're likely seeing higher oil temperatures and shear forces than most cars will ever see. Which is to say synthetics might provide more value than one might think if they're dismissed because marine motors run cool.
Except for the XS550, PCM recently changed its recommendation to Castrol HD40 and 30 hour change intervals if you run your at high RPM or under high load. In the TSB, PCM references that Castrol HD40 is designed to provide greater protection against thermal breakdown....and further states the 30 hour interval provides further protection against thermal breakdown. Which indicates PCM has seen thermal breakdown problems.
I run Delo 15-40 currently, but am thinking of switching to a synthetic notwithstanding PCM's recommendation. At the very least, I'll switch to HD40 at my next change.
and on viscosity:
