exhaust manifolds salt nautique 200
  • laurie8888
    • Dec 2011
    • 162
    • dubai
    • nautique 206 and 200
    Is there any recommendation/ advice on how long one should wait to change gaskets in manifold risers for boats sitting in salt
    I had a bad experience once on the
    206 where i got water into the oil and dont want to repeat. Cant see any visible leaks/ rust stains so far
    cheers
  • gride
    • Jun 2007
    • 1441
    • War Eagle
    • 05' 210 team
    do you have closed loop cooling and a flush on it? in that case i'd say about 4-6 years depending on how salty. you can and should replace the gaskets and hardware sonner than that though. nautique parts has packages already made up. i just got one for my excalibur 330.
    • gride
      • Jun 2007
      • 1441
      • War Eagle
      • 05' 210 team
      i just realized what i wrote about the closed cooling and flush are a non issue related to the manifolds/risers. i already knew that so i apologize for the mix up. however, it should be closed cooled w/ the flush.
        • 2908
        Do CAT manifolds still have this issue?
        • gride
          • Jun 2007
          • 1441
          • War Eagle
          • 05' 210 team
          i have no idea. i know the crusader engines are fully closed which would eliminate this issue. i'm still wondering why a half system is even installed when a full system is/was available.
          • laurie8888
            • Dec 2011
            • 162
            • dubai
            guys
            I do not have closed cooling engine. I have flush kit and flush after every use, but still wondering how often these graphite gaskets should be replaced before they perish
