03 super air gas gauge quit working
  • DePaepe
    • Aug 2012
    • 12
    • woodland, ca
    • 96 Ski Nautique 176 75 Ski Tique
    Gas gauge quit working today on my new to me 03 super air. I am thinking sending unit. I will pull it and test it with the ohm meter. The wires going to it from the boats harness tested good. Any other suggestions? Thanks!
  • DePaepe
    • Aug 2012
    • 12
    • woodland, ca
    Just searched this topic now that I am on the computer and not my phone.... Seems to be a common problem. Will test sending unit and go from there. Thanks
    • DePaepe
      • Aug 2012
      • 12
      • woodland, ca
      Pulled out the sending unit, tested the ohms with a volt meter. With the volt meter hooked up and then sliding the float up and down the shaft, I registered no ohms on the volt meter. Hopefully that is how you test it...... Ordered a new sending unit a few minutes ago. Will update when it arrives.....
      • DePaepe
        • Aug 2012
        • 12
        • woodland, ca
        New sending unit from nautique parts did the trick. All fixed, good to go. Note- with the new sending unit I was able to "test it" like I did the old one and get the meter to register some ohms as I slid the float up and down.
