What's the trick to replacing the pre-filter? What part should I be disconnecting and/or unscrewing from the fuel line? Thanks!
Originally posted by Quinner View PostTool,
Do you know what years/models are equipped with the pre-filter? Is item#21 the filter/gasket in question?
Thought I read not all Excal's have the pre-filter, ICBW though.
A site not our favorite shows 2005/6 only. (see link) I think that matches the book I grabbed the image from years ago. There might be a few other serial numbers with them. You never know what makes them decide these thing. The good news is you can see the little housing. I have the part but never changed it. Every year I say I will then put it in the water and spend the time using it.
http://www.skidim.com/prodinfo.asp?number=RP077014
I assume skidim go the years from the PCM part number shown.
