Horn volt meter???
  • cguse13
    • Aug 2012
    • 96
    • Broken Arrow, Ok
    Horn volt meter???
    Ok my horn and analog volt meter are not working but the volt meter in the tac does.. I have checked the fuses. Does anyone have a pic of where these things connect? Or can they explain it.
    05-210.
    2005 Nautique 210
    96 Mastercraft Prostar 205
    94 Malibu Euro f3
  • sodbuster88
    • Nov 2008
    • 368
    • Clayton, NC
    05-210.
    Sounds like you have two different issues that may or may not be related. If this is a limited or team, then you would have faria gauges and keypad...correct?
    If so, then regarding the volt meter, your instrument gauges are connected to a gateway box via a serial data and power bus that is in series. So power, gnd and data wire connect into one gauge and then daisy chain to the next...then to the next...etc. If there is a bad connection in the chain, all instruments downstream of the fault should not work. You can study this here: http://faria-instruments.com/site_manuals/IS0219_A.pdf
    Regarding the horn activated through the keypad, I could not find a wiring dgm or schematic. Guessing there is an expert here that can guide you...but I would work the gauge issue first so as to isolate the the two problems if possible.
    Peace..
    • cguse13
      • Aug 2012
      • 96
      • Broken Arrow, Ok
      Thanks for your reply I had done a couple searches last night but your description made the light go off
      You are correct it is a team
      2005 Nautique 210
      94 Malibu Euro f3
      • cguse13
        • Aug 2012
        • 96
        • Broken Arrow, Ok
        Ok pulled it all apart today the volt meter was fully plugged in. It would not lite up and would make a ticking sound and it appeared the needle on the volt meter tried to bounce... Think it just needs replaced?
        2005 Nautique 210
        94 Malibu Euro f3
        • cguse13
          • Aug 2012
          • 96
          • Broken Arrow, Ok
          Oh and on the horn issue tracked it down. I am getting 12 volts at the horn. Still no sound.. But took it off managed to dump some water out of it. And currently drying under a heater
          2005 Nautique 210
          94 Malibu Euro f3
          • jeepn
            • 164
            • DFW, Texas
            • 1992 Ski Nautique - since 2001
            My horns had gotten to that point in my 92 Ski. I just went down to pep boys and bought a set of horns and replaced. Highway horns may have been over the top, but hey turn heads when I engage horn
            Scott
            92 Ski Nautique
            • sodbuster88
              • Nov 2008
              • 368
              • Clayton, NC
              You might contact the guys at Faria (tech support) before you buy a new volt meter. Guessing they could advise on the best next step...but yeah, sounds like an issue with it.
              Peace..
              • sodbuster88
                • Nov 2008
                • 368
                • Clayton, NC
                Happened to think of something else. Just because the connectors are plugged in doesn't always mean they are actually making contact. Pull the connectors out and inspect carefully that you don't have a "pushed" pin or socket in that harness connector. You will want to inspect both the connector behind the voltmeter and the one from the up-stream gauge where it comes from. A pushed pin or socket may touch it's mating pin or socket but not fully engage...resulting in intermittent or insufficient current or signal transfer. If you find one pushed out slightly, you should be able to just snap it back in place unless the retention feature has been broken.
                Peace..
                • cguse13
                  • Aug 2012
                  • 96
                  • Broken Arrow, Ok
                  Good idea to check with faria and the upstream gauge. I didn't look at it...
                  2005 Nautique 210
                  94 Malibu Euro f3
                  • cguse13
                    • Aug 2012
                    • 96
                    • Broken Arrow, Ok
                    Just FYI was the volt meter plugged in the new one and all good
                    2005 Nautique 210
                    94 Malibu Euro f3
