2002 SAN Impeller Problem After Annual
  • SprintST
    • 14
    • Gilbert, AZ
    • 02 Super Air
    Boat was running fine but after doing the annual the cooling system was no longer working/passing water. (Tested in the driveway with Fake-A-Lake). I changed the impeller, thermostat, and a few cooling hoses.
    First thought was maybe I put the thermostat in backwards. Pulled the thermostat and it was in correctly. Decided to reassemble without the thermostat to eliminate it as a variable. Still no water passing.
    Concerning the impeller that seemed simple enough. New impeller, new o-ring, coated with dish soap and reinstalled. Unless I missed something the impeller housing can only mount one way.
    I tested with the fake-a-lake before doing the annual so I know everything was working correctly. The problem has to be something I did.
    Anybody have any ideas on where I went wrong and what I should check?
  • Chexi
    • Jan 2025
    • 2119
    • Austin
    • 2000 SAN
    You probably mounted the impeller pump upside down.
    Now
    2000 SAN
    Previously
    1999 Air Nautique
    1996 Tige Pre-2000
    • SprintST
      • 14
      • Gilbert, AZ
      • 02 Super Air
      Problem solved: I flipped the impeller pump 180 degrees.
      Thanks Chexi.
