Wakemakers coming through with some welcome innovation for extra ballast in our boats
  • Clibka
    • Dec 2012
    • 406
    • Illinois
    • 2021 G23 2012 210 SANTE (Previous)
    I just got off the phone with Jason from wakemakers about piggybacking some ballast into my new 210, and while discussing potential damage to tanks through vapor lock he informed me that within the next week or two they will have a bypass system that can be ordered with your system to eliminate that risk. Completely reversible and easy to install just like their current offering. Price isn't set yet. I for one was somewhat worried about going the piggy back route from the horror stories about tank damage. But this makes me feel a whole lot better about it.
    If you we're thinking of upgrading hold off for a bit, I think it will be a solid, cost effective solution to this little issue.
    Looks like 2x750#'s and the bow sack will be headed my way in a couple weeks!!!
    First and Current - 2012 210 SANTE
  • Whitetail15
    • Apr 2010
    • 603
    • 2016 G23 H6
    we are on the same page. i just had same conversation with them last week. i already own the 400 sacs from another boat, hope they will work. i dont think you can fill the 750's all the way anyway so they should be ok.
    2016 G23
    • HS
      • Oct 2007
      • 1333
      • Sammamish, WA
      • 2010 SANTE 210 (Sold)
      SacSurfer posted pics of full 750s in the locker on top of factory tanks. I have 750s plumbed in as well.
      • Miljack
        • Dec 2004
        • 1616
        • Charlotte, NC
        • '08 230 TE ZR6
        750's FULL on top of the stock 210 tank?? Maybe full with the tank removed? I've regularly ridden in a '08 210 w/stock and piggybacked 400s on top, and they filled up the storage. Are some of the different model years spec'd with a different rear tank?
        2008 230 TE-ZR6
        • Nordicron
          • Sep 2009
          • 557
          • Madison, WI
          I'm guessing atleast 600lbs goes in because I need to cycle my pumps several times to get the 750s full. And this trick will solve the tank collapsing issues.
          • Clibka
            • Dec 2012
            • 406
            • Illinois
            This, apparently they are longer so they barely fit. None the less a 750 3/4 full is still 562.5 lbs or 325 total extra over the 400's. And unfortunately I don't have 3 small bikini clads at my disposal to make that up just yet, so I need all the help I can get.
            • Clibka
              • Dec 2012
              • 406
              • Illinois
              I saw that and was quite interested in how it was accomplished. Did you do a write up on the install anywhere? I thought I read all the piggy back forums.
              • OKWAKEBDR
                • 750
                • Lakefront
                • 2017 Super Air Nautique G23
                750s fit just fine and will fill nearly all the way (if not completely full). I have them in mine. Used some zip ties in mine to prevent vapor lock.
                Current: 2017 G23
                • Nordicron
                  • Sep 2009
                  • 557
                  • Madison, WI
                  Not much to write up really but I think it may have been mention before. Basically just take the 1/4" tubing and run it from the inlet to the overflow fitting and secure like the pics show with the string. This way a vacuum can never be created due to the 1/4" tubing running inside the bag from the inlet to outlet.
                  • slob02
                    • Sep 2003
                    • 333
                    Thanks for the info!!!! I will wait and get the new system.
                    2008 Super Air 210 Team
                    2004 AIR 206 Team
                    1997 Ski Nautique 196
                    1993 Ski Nautique SNOB
                    • msbowhunter
                      • Aug 2011
                      • 100
                      • collierville tn
                      • 2011 SAN 210
                      Removing the hard tanks in the rear was best mod. I have done so far!! Put and Enzo on port side and a 750 on the other.
                      • Miljack
                        • Dec 2004
                        • 1616
                        • Charlotte, NC
                        • '08 230 TE ZR6
                        How are you guys with the 750's on top of stop tanks stopping the "siphoning" effect? Are you putting the fill fitting towards the front? Are you putting valves on the vent hoses? Friend's 210 would start siphoning off the 400's unless you broke it.
                        2008 230 TE-ZR6
                        • Nordicron
                          • Sep 2009
                          • 557
                          • Madison, WI
                          I use a couple of 90 degree elbows at the through hull to get the hose as high as possible in the gunnel if that makes sense. I've also heard that you can run the vent hoses to opposite sides of boat. I still sometimes get siphoning if my bags fill weird(meaning the bags are rolled over or folded on themselves) will have to hit the fill again to top off.
                          • Miljack
                            • Dec 2004
                            • 1616
                            • Charlotte, NC
                            • '08 230 TE ZR6
                            @Nordic, are you using 750's on top of stock? Also, I think the overflow setups take longer to fill because the pumps have "head" pressure to fill the bags, so they won't pump as fast for the initial filling of the hard tanks. I'm just surprised the 750's would fit at all in there, I've got 750's in my 230 lockers, and they fill that space up almost 100%, lockers are longer and wider on the 230 (210's are deeper).
                            Thanks for the pics on your "anti-collapse" setup, I'm going to set up my locker sacs like that as well...
                            2008 230 TE-ZR6
                            • Nordicron
                              • Sep 2009
                              • 557
                              • Madison, WI
                              Miljack- yes using the 750s on top. I agree pumps may not be as efficient pushing water through the tank to fill the bags as just filling the tank. But with the impeller design and speed at which they turn I'd think it wouldn't be much. Anyway I got into this debate on the Malibu crew site last year and have been meaning to do a test where I fill my 750 and then take my other 750 and fill it on the floor from the bag in the locker to see exactly how "full" the bag in the locker gets.
                              Even though the hatch itself isnt overly large, when you take the liner out of the compartment there is a lot of space available for the bag to expand in the 210 lockers.
