PP Install on 95 Super Sport+Tip
  • btdaly
    • Aug 2008
    • 4
    Servo Motor Mounting
    Wake fun,
    I just installed PP on my 96 SS. Can you post a picture of where you mounted the servo motor. I mounted it on the passenger cooling line, but I'm not sure if that is the best location. Any suggestions are appreciated.
    Thanks!
    • wake_fun
      • 1330
      • CA
      • 1995 Super Sport
      RE: Servo Motor Mounting
      That's the right spot!
      Photo Album
      Ballast Install 1
      Ballast Install 2
      Amp Install
      PPass Install
      Alternator Install
      • east tx skier
        • 1561
        • Tyler, TX
        Fantastic idea! Nice work!
        • wake_fun
          • 1330
          • CA
          • 1995 Super Sport
          Thanks!
          Photo Album
          Ballast Install 1
          Ballast Install 2
          Amp Install
          PPass Install
          Alternator Install
          • btdaly
            • Aug 2008
            • 4
            Re: RE: Servo Motor Mounting
            Thanks! wake_fun,
            I was concerned because my servo cable comes up above the top of the motor. You can see the mount in the picture below, but it is hard to tell that the cable is above the motor. What this means is that when I close the back hatch it is pressing down on the cable. This does not seem to hurt the performance of the PP, but I was wondering if this is the best spot for the motor. I just wanted to see if you ran into the same thing.
            Thanks again!
            • wake_fun
              • 1330
              • CA
              • 1995 Super Sport
              #21
              RE: Re: RE: Servo Motor Mounting
              Let me get a picture of mine for you.............
              Photo Album
              Ballast Install 1
              Ballast Install 2
              Amp Install
              PPass Install
              Alternator Install
              • wake_fun
                • 1330
                • CA
                • 1995 Super Sport
                #22
                Here you go!
                Photo Album
                Ballast Install 1
                Ballast Install 2
                Amp Install
                PPass Install
                Alternator Install
                • btdaly
                  • Aug 2008
                  • 4
                  #23
                  Here you go!
                  Was away for the long weekend - boating and camping. Had beautiful weather.
                  Thanks a bunch! Yours looks close to mine but a little different (better). I like how your cable is running. I will have to take a closer look on mine tomorrow to see what the difference is. Thanks again -- I appreciate the pictures.
                  • btdaly
                    • Aug 2008
                    • 4
                    #24
                    Here you go!
                    Thanks!
                    Yeah, there are a couple of cooling lines that run across the engine there. You have yours mounted on the one farthest toward the rear of the boat. I had mine on the next one towards the front of the boat. Yesterday, I mounted the motor the same way as yours and it is much better! The cable does NOT get in the way of the rear hatch. Thanks a ton for taking and posting the pictures -- I really appreciate it. I think it will work much better and last a lot longer mounted this way. :grin:
                    • wake_fun
                      • 1330
                      • CA
                      • 1995 Super Sport
                      #25
                      Your welcome. Glad that you got it mounted better using the pics.
                      Photo Album
                      Ballast Install 1
                      Ballast Install 2
                      Amp Install
                      PPass Install
                      Alternator Install
                      • tiqueman97
                        • Oct 2006
                        • 81
                        • Parrish FL
                        #26
                        wake_fun,
                        Your spread on the PP install is great. Gave me that extra confidence that I was infact doing everything correctly, especially the paddle wheel. Great idea w/ the magnets, that worked wonderfully. Install was cake at just over 3 hours from uncovering to covering the boat back up. A lot easier than installing my hard tank ballast. And best of all, it worked... "Perfect"
                        Thanks again!
                        Past: 82 2001
                        Present: 97 Super Sport / SAN
                        • wake_fun
                          • 1330
                          • CA
                          • 1995 Super Sport
                          #27
                          Awesome! Good to hear someone else used my idea and it worked perfect!
                          Photo Album
                          Ballast Install 1
                          Ballast Install 2
                          Amp Install
                          PPass Install
                          Alternator Install
                          • wake_fun
                            • 1330
                            • CA
                            • 1995 Super Sport
                            #28
                            Bump
                            Photo Album
                            Ballast Install 1
                            Ballast Install 2
                            Amp Install
                            PPass Install
                            Alternator Install
                            • WakeSlayer
                              • Sep 2005
                              • 2069
                              • Silver Creek, MN
                              • 1968 Mustang
                              #29
                              A little trip down memory lane this afternoon? You do good work, dude.
                              Mike
                              the WakeSlayer
                              1968 Correct Craft Mustang
                              • EchoLodge
                                • Jan 2004
                                • 616
                                • Huntington Beach, CA
                                • 99 Super Sport
                                #30
                                I have read that you can use the throttle cable to fish the servo wire harness to the dash. I was thinking of just running it down the driver side gunnel. My PP kit is 300 miles away with my boat. Is the harness long enough?
                                sigpic
