Need Advice - Experiencing high torque (RPM) problems with PCM 351 Pro Boss.
  • Sandro
    • Jan 2012
    • 37
    • Tbilisi, Georgia
    • Ski Nautique 176, 1994 Ski Nautique 206, 2008
    Hi
    Im Experiencing high torque (RPM) problems with PCM 351 Pro Boss. When the engine starts, the RPM goes to 1500-1800 RPM and goes down very slowly back to 1000-900 RPM. I need to wait a minute or even more to shift the gear. Sometimes I have to switch the engine off, because, it never calms down. I dont want to make some problems to gearbox.
    If you know what can be a problem please let me know.
  • NCH2oSki
    • 1159
    • Maryville, TN
    • 2005 ski nautique 206 SE
    What year? Carb or Fuel Injected?
    Prior Boats:
    1999 Ski Nautique GT-40
    www.skiersofknoxville.org
    • Quinner
      • 2246
      • Correct Crafts
      Do you have perfect pass?
      Would start by checking the throttle cable, be sure it is not under pressure against the shroud, a hose, etc.
      • Sandro
        • Jan 2012
        • 37
        • Tbilisi, Georgia
        Its 1994 model year with fuel Injected engine. (Pro Tech Injection)
        • TX-Foilhead
          • Mar 2009
          • 351
          • Kingsland TX
          The ProTec does wierd things as is goes out, that would be my first guess as to what is happening. Unfortunately there is no fix for it because parts are no longer available. You need to change it out to a carb and a distributor. PCM sells a kit, but since your on the opposite side of the world it may be easier to do it yourself.
