what to clean flame arrester with?
  • gride
    • Jun 2007
    • 1441
    • War Eagle
    • 05' 210 team
    call me dumb, but what exactly do i use to clean my flame arrestor?
  • shag
    • 2217
    Some one else may chime in, but I used to take it off, spray carb cleaner from the inside out, then let it dry good before putting it back on.
    • LakeRats
      • Jun 2012
      • 50
      • North Carolina
      • 2012 Sport 200V
      ditto
      • gride
        • Jun 2007
        • 1441
        • War Eagle
        • 05' 210 team
        thanks. so no need to rinse with water and let dry again?
        • shag
          • 2217
          I had never rinsed mine after... But it can't hurt. If I did, I would probably blow it dry with some compressed air... Since it is metal, there shouldn't be a worry to damage anything with the compressed air.
          My disclaimer: I am not a mechanic....
          But it has worked fine for me for years and years doing it that way.
          • scottb7
            • Aug 2011
            • 2198
            • Carson City, Nevada
            I think i just used mineral spirits and shook it out hard.
            • Mark2
              • Nov 2010
              • 38
              • Toronto Canada
              • 2008 SV211 Team
              let it soak in some mineral spirits or varsol and blow it out to get everything out of the fins
              • Zach@n3
                • Sep 2012
                • 736
                • Indianapolis Indiana
                Best way I have seen is an actual parts washer. But I like Scott's idea.
                • AirTool
                  • 4049
                  • Katy, Texas
                  That's right. If its real gummy, the gum is going to need some kind of force to get it off.
                  I like the idea of soaking overnight or so and then use a fresh can of carb cleaner to blow through the fins. Then let it dry in the sun if you like.
                  I wouldn't use any water.
                  • east tx skier
                    • 1561
                    • Tyler, TX
                    This is exactly what I do.
                    • sputnic6
                      • Dec 2006
                      • 15
                      I used some brake cleaner and it did the trick (with the flame arrestor off the engine of course) :-)
