T-H ballast valve replacement notes,
  • hsmunoz
    • Nov 2004
    • 191
    • livermore
    I spent about 90 minutes replacing the stock red plastic ballast valves, with the T-H RDV-2's that Mike-d posted on another thread. here are my notes
    first off, the stock valves are JUNK!!!! , they aren't worth the space they take up, everyone of them I could blow through when they are closed, happy to see them go into the crapper. If you think the dealer is going to fix this flaw, it's just a matter of time before they fail. My boat has 150 hrs.
    ok now for the good stuff.
    1. The T-H VALVES operate out of the package BACKWARDS of the stock valves. Meaning when the cockpit actuator is in the "closed" position the cable is extended, and the position of the T-H valve would be "OPEN". a quick fix is to unscrew the actuation lever on the valve, which is keyed by a square notch, and move it 90 degrees clockwise , or counter clockwise. Then replace the screw and make sure that when the actuation arm is "fully extended" the vavle is closed.
    2. The next thing is that the actuation arm has a small hole to feed the cable into, this hole is too small and you will have to drill it out not much I used 1/16 bit.
    3. One of my valves has exessive flashing, inside , so I took it apart and used an exacto blade to clean it up, in fact I did all three just to make sure things were sano. Also, you will need to remove the screw that is used to hold down the cable, and trim the plastic standoff flush.
    4. One valve was sticky, so I took it apart and lubed it with silicone grease. Make sure all the valves upen and close easily.
    5. Center ballast tank is a a breeze, under the ski locker, there is a panel that is removed with two 7/16 bolts and 3 philips screws, remove the old valve and replace with new, this is the confidence builder, 15 minutes tops!.
    6, OK now for the port and starboard. I got to both from on top, no need to pull up the floor. First the port, disconnect from the thru-hull side, then pull it up for better access. Disconnect the other side, then work the cable free, remove and replace. Same with starboard side, only this one requires patience and some contorting. What I did, was set the cockpit actuator to "OPEN" (Cable fully retracted) , manually set the valve to full open (closed has alot more slop to play with , but I wanted fully open to be perfect) then I attached the metal part of the cable, and tighted it in place. Then checked for proper cable travel.
    7. Lastly DO NOT OVER TIGHTEN the steel hold down screw that tightens the metal pinch clamp on the cable. I found out that this was a cause of sticking cables. It needs to hold the cable in place , that's all.
    If everything lines up, the plastic end of the cable (before the small metal wire comes out) should be just before the first screw on the valve.
    and your done! in my opinion this is an absolute no brainer, if your valves are leaking, which is inevidable (sp).
    thanks Mike!
    2004 SV-211 Team
    Silver cloud deck, Onyx Hull.
  • hsmunoz
    • Nov 2004
    • 191
    • livermore
    RE: T-H ballast valve replacement notes,
    a quick side note,
    I kept playing with the starboard valve because it was sticky , and it turned out that the cables were kinked alittle due to the tie wraps that the factory put on. These ty wraps, anchored the cables to the thruhull's.I cut them off. what I did was pull off the 3/4 hoses that connect to the valves, then snake the valve out, through the small plastic hatch above the drain plug. Now you have the old valve (or the new one) in your hands sitting in the boat. Then you can connect it up , play with it, to make sure that it functions properly,and then snake it back into the bilge. Then slip on the hoses , tighten , and done. This is easier that my original "come in from above route)
    2004 SV-211 Team
      • 2908
      Great job Henry, thanks for getting this figured out now I can benefit from your experience.
      Mine are not leaking too bad yet, it's kind of intermittent. By the end of the summer I fully expect to upgrade not only my valves but also the little pumps.
      • jwhposon
        • Mar 2005
        • 159
        • Oregon
        Are they bad in SAN 04's as well?
        Mike or anyone, I am curious if the SAN 04 has the same crap valves and I noticed there are two different valve controls. I have all three ballast tanks and there are the three controlls up where the drivers feet are and then there are control valves just inside the engine cover close the to transmission area I think. Are these the valves you changed or was it the ones that the three controls control? Sounds confusing huh..... OR are the valves located in the engine compartment a fix to the crap valves?
        • Roddbod
          • Sep 2004
          • 116
          Jwhposon,
          Yes the 04's had the crapy valves too. I have an 04 as well and tomorrow Im going to change mine out as well. The valves are the ones that need to be changed are the ones that are controlled from where the driver sits. They should be red in color.
          • hsmunoz
            • Nov 2004
            • 191
            • livermore
            took the boat out for the first time since I changed the valves. These new valves do not leak at all. on the flip side I felt like the tanks took alittle longer to fill. Not sure, if that was the case before, because, now they were actually empty before I started filling them, where as with those lousy OEM valves, the tanks were 1/2 filled before I ever turned on the pumps. I guess you can't win them all...
            also these new valves are alittle harder to open and close, but not difficult.
            good luck guys,
            2004 SV-211 Team
            • Roddbod
              • Sep 2004
              • 116
              Hsmunoz,
              Just wanted to let you know I installed my valves in my 210. Its wasnt too difficult. I followed your insturctions, thans for the write up.
              Just for anyone reading this spend the extra money and get these valves, they work 1000 times better than the stock one. The stock ones are junk. If anyone wants a pair of them you can have mine.
              I hope correct craft reads these forums on this because they really need to change suppliers on these valves. Just my $.02
