No power to keypad and everything is dead
  • blr0064
    • Aug 2010
    • 3
    • Midland, TX
    • 2005 SV211
    I have a 2005 SV 211 and I had been having some trouble with the toggle switch which was causing the boat to have some trouble starting and dying when hitting a wave. Yesterday went to start it up and now there is absolutely no power to the keyboard and everything was dead. My batteries are new and we checked all connections to and from the batteries. Was wondering if this toggle switch is what is causing no power to get to the keypad. Any help or advice would be awesome!!! Thank you!!!
  • AirTool
    • 4049
    • Katy, Texas
    Maybe I should write a macro to respond to these toggle posts.
    http://www.elecdirect.com/product.aspx?id=12484
    http://www.elecdirect.com/product.aspx?id=13426 (handy to make splash proof)
    http://www.planetnautique.com/vb3/sh...ghlight=toggle
    http://www.planetnautique.com/vb3/sh...ad-2005-210-TE
    https://www.google.com/#hl=en&sclien...w=1280&bih=628
    • jward
      • Feb 2008
      • 620
      • Sweet Home Alabama
      • 03 SANTE 04 SANTE
      Check the obvious. Make sure you are in neutral. Check kill switch. Check toggle. Straight line both if you need to. My guess is one of those is your fix. I have an 04 210 and i started having trouble with my toggle when hitting double ups. Everything looked good on the connections. Upon further inspection the ground was just barely loose. Bought another toggle from my local car quest and I've never had another issue. Good Luck.
      • blr0064
        • Aug 2010
        • 3
        • Midland, TX
        • 2005 SV211
        thank you so much I am on it today!!
        • jward
          • Feb 2008
          • 620
          • 03 SANTE 04 SANTE
          Any luck?
          • AirTool
            • 4049
            • Katy, Texas
            Originally posted by jward View Post
            Any luck?
            ditto and I post simple symptoms of the other two jward mentioned if you don't have it done yet.
            • Woody_tobius_jr
              • Dec 2012
              • 248
              • Alberta, Canada
              • 2004 SV211 Air Nautique TE
              I just bought an'04 sv211. Very good info...I think I'll pick up a spare switch just in case. Is this something that can be changed fairly quickly on the water if necessary or do you have to pull half the boat apart to change it out?
              • jward
                • Feb 2008
                • 620
                • 03 SANTE 04 SANTE
                It's a 2 minute change of switch.
                • Woody_tobius_jr
                  • Dec 2012
                  • 248
                  • Alberta, Canada
                  Perfect, thanks a lot!
