BoatMate Trailer Lights Blinking
  • axeman
    • Apr 2012
    • 387
    • Dallas, TX
    • 2016 Super Air Nautique 230
    Anyone with a newer BoatMate trailer experience the blinking lights when underway? If brakes are on they work correctly. Once I take my foot off the brake all lights on trailer flash constantly (only when lights are on obvisously). Seems like people with Land Rovers have run into this issue (I'm having the issue with a Mercedes Benz ML). Can anyone here provide some advice on how to fix?
  • 2004196
    • Dec 2007
    • 162
    • University Place, WA
    • 2006 196LE
    Try adding another ground wire from rig to trailer separate from the wire harness.
    2004 196 LE Black/Grey
    330HP Excalibur Water Churner
    2002 Grey F150 Harley
    475+HP Supercharged Tire Burner
    • RideButter
      • Feb 2011
      • 189
      • Fuquay-Varina, North Carolina, United States
      • 2015 A22 2014 A22 SOLD 2009 210 SOLD 2007 210 SOLD
      Are your vehicle lights blinking along with the trailer lights?
      LEDs for trailer lights?
      [URL="http://www.ridebutter.com"]http://www.ridebutter.com[/URL]
      • axeman
        • Apr 2012
        • 387
        • Dallas, TX
        My vehicle lights operate normally. It's the trailer lights that are blinking. Yes, trailer has LED lights. I didn't have this issue with my last trailer that also had LED lights (albeit it was a Dorsey trailer).
        • jankedm
          • Oct 2010
          • 23
          • Spokane, WA
          • 2002 Nautique Super Sport
          You probably don't have enough resistance in the system. Without an incandescent bulb or some type of a resistor in-line, I think your lights will flash. I bet your other trailer that worked had somthing built in already. One thing you might try is an adapter like this one:
          http://www.uhaul.com/MovingSupplies/...Module?id=4089
          Hope I am not steering you in the wrong direction.
          David
          • axeman
            • Apr 2012
            • 387
            • Dallas, TX
            Unfortunately, the trailer adapter and cable are one unit so I can't use the standard 4 -> 7 pin adapter that would resolve this issue. I'd have to find a male to female 7 pin adapter to put in between the adapter and the plug in my SUV...
            • s_kelley2000
              • 1575
              • Fort Meadow Recevoir
              • Mass
              etrailer.com has all sorts of adapters so they might have what you need. Good luck, I hate dealing with trailer light issues.
              Shawn
              2012 Blue Metal Flake SAN 230
              • axeman
                • Apr 2012
                • 387
                • Dallas, TX
                etrailer.com is where I buy all my trailer accessories. Unfortunately, they don't have anything that would work in this case. I've contacted BoatMate directly and they said that Mercedes should be able to flash the ECU to make this work. I know that's a fix for Volkswagen, Audi, BMW but not for Mercedes. I actually contacted my Mercedes mechanic (head mechanic at the best Mercedes dealership in Dallas) and he's never heard of such a thing.
                • axeman
                  • Apr 2012
                  • 387
                  • Dallas, TX
                  By the way, I actually called etrailer.com to see if they had a 7-way -> 7-way adapter that resolves the same issue as the item below does but they said that is the only item they sell for this specific issue...
                  http://www.etrailer.com/Wiring/Tow-Ready/TR20141.html
                  • axeman
                    • Apr 2012
                    • 387
                    • Dallas, TX
                    Jerry @ BoatMate has been very helpful with this. It turns out the adapter that comes with the trailer is 7-way on one end and on the other end a 5-way with an 8 ft cable in between. I will be replacing this with the following from Wesbar. Then I should be able to use the 7-way to 5-way adapter from etrailer.com to make this all work.
                    http://www.wesbar.com/content/produc...75&part=787194
                    I will report back to let everyone know if this worked or not. By the way, if I wouldn't have been able to find this cable online Jerry @ BoatMate was willing to create a custom cable for me (I know it's pretty straightforward and I could do this myself but that's good customer service IMO).
                    • axeman
                      • Apr 2012
                      • 387
                      • Dallas, TX
                      This does work now. Glad it's all sorted out!
                      • DealsGapCobra
                        • May 2010
                        • 375
                        • Knoxville, TN
                        • Ski Nautique 200
                        BoatMate is absolutely top notch with customer service. I am glad you have it working now.
