343 transmission service????
  • Neverenough
    • Sep 2012
    • 907
    • Ft. Worth Texas
    • G
    Anyone have any links to a transmission oil service on EX 343?
  • Nautiquehunter
    • Jun 2008
    • 2080
    I just change the trans oil every 50 hours using a vacuum fluid changer along with changing the engine oil . It only takes a qt to fill it.
    • Quinner
      • 2246
      • Correct Crafts
      On a direct drive 1:23 trans, IIRC manual says change every 100hrs or annually, best to change it at the end of the season. Use Dexmerc transmission fluid. Check level before you start, if it's full just replace what came out. I can usually get close to 2 qts out. Check it again after it's warm and level on the water.
      As Hunter mentioned, you will need a pump, Suck-up is the best one out there IMO, some guys will use a turkey baster, whatever works.
