How do I get 24 V for my heater?
  • polkaking27
    • Jan 2005
    • 104
    Unfortunately I purchased the 24 volt version of the heatercraft heater and I'm trying to figure out how to get the correct voltage to the heater. I currently run 2 batteries and know that I can wire them in series to get 24 v, but I don't want to wire the entire system to 24 v. Is there a way to pull power off of each battery and diode isolate so I can get 24 volts to my heater yet leave the rest of my system unaffected?
    Any ideas or diagrams would be helpful. I'm sure it can be done, I'm just not too familiar with increasing voltages.
    THanks
    if con is the opposite of pro, is congress the opposite of progress???
    Contact Heatercraft. See if they will change your 24 volt motor for a 12 volt one.
    • polkaking27
      • Jan 2005
      • 104
      That was the first thing I thought of. Although I bought the heater brand new, still wrapped in its packaging, I got it off of ebay. I have a feeling heatercraft won't exchange something from there. I still plan on asking, but assuming they won't do it I want to be prepared.
      • axeman
        • Apr 2012
        • 387
        • Dallas, TX
        • 2016 Super Air Nautique 230
        Does the same eBay seller sell the 12 volt one by chance? If so, that's worth a shot to try to get it exchanged...
        • shawndoggy
          • Aug 2011
          • 151
          • Reno
          • MB Sports TWB 23
          it'll still work, just won't blow as hard.
          http://www.heatercraft.com/300h-400h-blower/
          • Mark56
            • Jul 2007
            • 36
            • AU
            You will need a step up transformer to convert 12v to 24v pretty cheap on eBay
            • AirTool
              • 4049
              • Katy, Texas
              Trying to stick with your question, I'm thinking no but going to sleep on this.
              • shawndoggy
                • Aug 2011
                • 151
                • Reno
                • MB Sports TWB 23
                great call Mark56!
                looks like a step up of questionable origin is still $75 tho, versus the "right" part and potential for resale of the 24v blower for $140.
                20a capable step up aint cheap.
                (i bought one of the same heaters on ebay... too cheap to ignore)
                • scottb7
                  • Aug 2011
                  • 2198
                  • Carson City, Nevada
                  Which one are you buying on ebay that is so cheap you can't ignore? Now, you got me curious?
                  This one seems like a good deal with 3 outlets, if it would work...http://www.ebay.com/itm/Yamaha-Rhino...37d7bf&vxp=mtr
                  Jeez, people are paying a lot more for just seadek arent they?
                  The whole thing is like under $500 on nautique parts.
                  http://www.nautiqueparts.com/heaters...mpletekit.aspx
                  • polkaking27
                    • Jan 2005
                    • 104
                    Thanks for the responses guys. Before i started this thread I looked into the step up transformers and I couldn't find one that could handle the blowers amperage, at a decent price. I know that I can wire the 2 batteries in series to get 24 volts, i just didn't know if it would short something out if I didn't diode isolate it some how.
                    Anyway, I talked to Josh over at Heatercraft and he gave me a couple ideas. He said the 24 volt blower has a much longer continuous duty cycle and will last 20% longer than the 12 volt version. He told me how I could try to wire it to see if it would work. He also offered to exchange the 24V blower for a 12V blower for me. What a great company, they are willing to do whatever it takes to make it work for a customer!
                    I'm going to try and wire the batteries to get my 24 volts and see what happens.
                    Shawndoggy- what are you doing to get your heater to work?
                    • shawndoggy
                      • Aug 2011
                      • 151
                      • Reno
                      • MB Sports TWB 23
                      I'm just wiring mine up to 12v. I did a test on my batteries (pulled from boat for the winter) in the garage, and it seemed to blow pretty hard. I looked at the manual for the 3 position heater switch and it looked like on the 12v version that medium was a little over half voltage, so I'm figuring that running at 14.4 on the 24v heater on the red wire will be about the same in our boat. Guess I'll find out when I actually get everything hooked up in the next couple weeks.
                      In my experience, it's not how hard the fan blows per se as it is how hot the water is running through the core.
                      In that respect this year I'm going to run a 12v circulation pump on the hot water line to keep the hot water flowing. I'm also daisy chaining this new core to an existing 2 vent heater that I had from the factory. so I'll have five vents, two cores, and a circ pump. Wish me luck on getting all that working
                      I'm certainly NOT going to try to simultaneously wire my batteries as 12 and 24v just to get the fan to blow a little harder. Seems like a good way to fry ecm, perfect pass, etc, just to get a little more airflow from the heater.
                      • polkaking27
                        • Jan 2005
                        • 104
                        thats a valid point shawndoggy, maybe I'll just opt for the 12v version so I don't accidentally fry something I don't want to replace. Good luck with everything
                          • 2908
                          Nope, step-up transformers only work for alternating current (A/C) they do not work on the direct current (D/C) electrical systems in our boats. You can do it with power electronic converters incorrectly labeled as step up transformers but I would not go that route.
                          As for wiring the batteries for 24V, you can only do that if you completely dedicate one of the 2 batteries to the 24V system, and you will have charging issues if you did that anyway. There are ways to do it with diode bridges and switching circuits but it will be cheaper to just buy the 12v blower motor or run the 24v motor at a reduced voltage.
                          • shawndoggy
                            • Aug 2011
                            • 151
                            • Reno
                            • MB Sports TWB 23
                            as a follow up, the three vent core with the 24v blower works fine.
