Swim Deck Hardwear
  • Johan
    • 7
    Swim Deck Hardwear
    I've got a 1989 Nautique. The swim deck has hardwear on it that allows the deck to come off for easier garage storage. The hardwear is pretty worn and I need new brackets. Any suggestions where to find some?
    Thanks.
  • wakejunky
    • 679
    • Ca
    • 2003 SAN
    RE: Swim Deck Hardwear
    Are they totally out of commision? If not then I would sandblast them and powder coat them and call it good. Otherwise you'll be hard pressed to find direct replacements.
    Chris
    • Johan
      • 7
      There pretty worn. Thinking of trying JB weld and sanding it down. The brackets are pretty loose.
      • ag4ever
        • 1180
        A powdercoat job might build enough thickness to bring them back into spec.
        • bkhallpass
          • 1407
          • Discovery Bay, CA
          Your brackets look about the same as those still used. Have
          you checked to see if the bolt patterns are the same?
          BKH
          2001 Super Air
          • Johan
            • 7
            Where can I get these ones that are still used? None of the boat shops have them. Thanks for the help.
            • bkhallpass
              • 1407
              • Discovery Bay, CA
              Well, if the bolt patterns are the same, I would contact Mid Ohio
              Watersports (advertised at the top of this page). They are usually
              very good to folks on this site, and offer a 15% disount to folks on
              this site.
              BKH
              2001 Super Air
              • Johan
                • 7
                Thanks for your help. Much appreciated.
                • Johan
                  • 7
                  • Johan
                    • 7
                    Mid Ohio Watersports can get them. Kellie wrote back with:
                    I do not have the swim deck brackets in stock, I can order them. The price is $187.80 with your Planet Nautique discount.
                    Thanks,
                    Kellie Repasky
                    But my buddy took them down to his welding shop and threw a couple of aluminum welds on the shafts then grinded them down to fit. Cost nothing and everything fits sweet.
                    • bkhallpass
                      • 1407
                      • Discovery Bay, CA
                      Well, it helps to have talented friends with welding equipment.
                      Glad it worked out for you.
                      BKH
                      2001 Super Air
