excalibur 330 cut out & hard start
  • Graeme V
    • Feb 2013
    • 48
    • Durban, South Africa
    • 1982 2001 2003 196 LE
    Hi all.
    I have a 2003 196 with the excalibur engine. It has always started first turn and never missed a beat. Yesterday for no reason while idling & waiting for a skier to get ready she cut out. I pushed the start on the keypad but all she did was crank over. After numerous attempts (maybe a minute) it started again but sounded as if it was flooded/over-fueled. I then revved it a few times & it cleared. It was the last ski of the day so we put it back on the trailer & went home. At home I cranked it over again & it started first turn. Has anybody had this happen before? Is there something i should check?
    Thanks. Graeme
  • HS
    • Oct 2007
    • 1333
    • Sammamish, WA
    • 2010 SANTE 210 (Sold)
    Not had it happen but it sounds like something I've read about here a few times before, the early signs of fuel pump failure...but maybe check the fuel filter first?
    • Quinner
      • 2246
      • Correct Crafts
      When was the last time the cap and rotar was changed?
      • Graeme V
        • Feb 2013
        • 48
        Thanks HS.
        Will go out to the lake and see if it happens again. the fuel filter is about 30 hrs old. i have a new pcm one and will replace it just in case.
        Graeme
        • AirTool
          • 4049
          • Katy, Texas
          That's where I'd start too.
          • Graeme V
            • Feb 2013
            • 48
            Thanks AirTool
            Checked cap & rotar last night & they looked good. Seen another post on this site with a similar problem & they say fuel pump relay/s. What do you think??
            G
            • AirTool
              • 4049
              • Katy, Texas
              Originally posted by Graeme V View Post
              Thanks AirTool
              G
              Fuel pump relays are common too and I almost said that....but that wouldn't result in the flooded fuel smell IMO.
