factory ballast tanks popping circuit when trying to empty
  • TMAHER
    • Mar 2005
    • 16
    does anyone know where the pump to drain the tanks on a 01 pro air is located? how many pumps does the system have? one to fill one to empty? any help greatly app
    tommy
  • Downsideup
    • Jan 2005
    • 53
    RE: factory ballast tanks popping circuit when trying to emp
    2001 Air Nautique
    http://www.downsideupvideo.com
    • Downsideup
      • Jan 2005
      • 53
      It's probably in the same place as my 2001 Air. Mine has 1 fill, 1 empty.
      2001 Air Nautique
      • Alan-S
        • Nov 2004
        • 161
        • Richmond, VA
        Had the same problem last year in my SAN. Just replace the pump, the motor is shot. West marine carries them in stock.
        • Downsideup
          • Jan 2005
          • 53
          Walmart, $18.22 or so (Atwood 750)
          2001 Air Nautique
          • TMAHER
            • Mar 2005
            • 16
            thanks for the help gentlemen
            • bfinley1977
              • Mar 2005
              • 41
              I have a 97 sport does anyone know were i can purchase a rear ballast tank for it like the one in the above pic?
              • Downsideup
                • Jan 2005
                • 53
                That's the gas tank.
                2001 Air Nautique
                • bfinley1977
                  • Mar 2005
                  • 41
                  the ballast tank on that boat is in teh back right?
                  • bfinley1977
                    • Mar 2005
                    • 41
                    i built a custom fat sac box that goes under the rear seat but i dont have much seat back now you have any suggestions
                    • Dr.John
                      • May 2004
                      • 225
                      • Austin, USA
                      • 2001 Sport/Air- SOLD
                      I think what happens is the pump shaft gets a little corrosion in the bearing area from sitting up, and "freezes". I had a similar problem and all I did was turn the shaft by hand until it was free, then shot a smidge of synthetic oil on the bearing area and it works fine...... at least so far!
                      The pump comes apart with a twist and you may not have to remove it from the hose.
                      BTW, that spiral reinforced hose is absolutely awful to remove, and if anyone has an easy way to remove the hose I'd love to hear about it.
                      \'01 Sporty Air Nautique
                      • wakejunky
                        • 679
                        • Ca
                        • 2003 SAN
                        That spiral hose is a pita to get off. If you can get it off, you're one lucky SOB, oh and try to get it back on. It's a wonder that the factory gets those hoses on at all.
                        Chris
                        • TMAHER
                          • Mar 2005
                          • 16
                          thanks
                          thanks for all the help! Dr John i think you may have my answer
                          it worked fine when put away last year 1st run this year had the problem thanks again
