dreaded limp mode and RPM reduction
  • johnboyy7
    • Oct 2009
    • 409
    • houston
    took boat out and surfed for about 1.5 hours, switched sides (for my turn of course) and the boat goes to limp mode after 2k RPM. I did some research on here and it looks like it could be the oil pressure sensor. Where is the oil sensor on an 04 210? is there any test i can do to validate this? Also, is there anything else it could be and that i can check?
    boat has 370 hours.
    04 SANTE 210
    89 SPORT
  • gride
    • Jun 2007
    • 1441
    • War Eagle
    • 05' 210 team
    the switch will be on the starboard side of the engine. I want to say it's closer to the "bow,and about mid way down the engine, maybe slightly higher." i had this problem and just clipped the wire one day out on the water and problems went bye bye.
    • nms1991
      • 477
      Gride is right, its where the oil filter would be mounted on a small block chevy, The sensor is about 1 1/4 inches in diameter and about 2 inches long, with a brass hex on one end and black plastic on the other end. It should have a light green wire that is held on a tab by a flat headed screw on a tab on the plastic end. If you disconnect it and retest the boat it should come out of limp mode. I would recomend replacing the switch if it is the problem as it could save your engine if it looses oil pressure.
      • johnboyy7
        • Oct 2009
        • 409
        • houston
        when yours happened did it show any loss of oil pressure?
        04 SANTE 210
        89 SPORT
        • nms1991
          • 477
          Does your engine loose oil pressure when it happens? There is two separate sensors in the system, one is for the gauge and one for the limp mode. but if the engine is loosing oil pressure then you have a problem in the engine, first check you oil level to see if you have not enough oil in your engine.
          • johnboyy7
            • Oct 2009
            • 409
            • houston
            changed oil pressure sensor. back running like a champ.
            04 SANTE 210
            89 SPORT
