Anybody tried vinyl dye?
  • ally505
    • Feb 2012
    • 180
    • Somewhere cold and wet
    • 2008 super air nautique 210, zr6.
    The engine box on my 97 Sport has some stains that simply will not come off. The boat is getting on a bit but in very good condition. I don't really see the need to re-cover just yet as this would be rather expensive and add no value to the boat. So I am considering using a vinyl dye to bring it back to the original white colour. Worst case if it goes wrong, I bite the bullet and replace the skin. If it does work then I may also consider changing the colour of the seat bases, currently a pale (and dated) shade of grey.
    Wondering if anybody has any experience of using vinyl dye, good or bad?
  • Prairiedawg
    • Jan 2013
    • 61
    • Saskatchewan
    • 2008 Super Air Nautique Team Edition, 'Rider Green and White!
    I know absolutely nothing about dye, and i dont know what you have tried, but check out my results using babes seat soap in the maintenance section, takes a lot of scrubbing, but may be worth a try.
    • Neverenough
      • Sep 2012
      • 907
      • Ft. Worth Texas
      • G
      Love me some babes. To condition with!! Go to the dollar store pick up some LAs totally awesome and a soft dish brush. Spray on the totally awesome use the brush to scrub , wipe off with wet towel and condition with the babes. Done! I think that dye will not do good in the sun and all of the stuff that happens to a boat. Water , sun screen, etc. I had the same on our boat before cleaning it looked gray. Now she's all white !!!
      • ally505
        • Feb 2012
        • 180
        Thanks for the tips. I've tried all the cleaning products I can get my hands on, unfortunately the marks simply do not shift. I'll try the dye out and see what happens, worst case I replace the skin... Will post some pictures for future reference.
        • ally505
          • Feb 2012
          • 180
          for anybody interested, the dye worked VERY well, it looks original. Product was made by Magix / Grison.
          I managed to get a tiny bit of overspray, which turned out to be a pig of a job to remove even onto vinyl that had protectant freshly applied, so I am confident the dye will wear well on the area that was fully prep'd. I'll probably paint the other white areas of vinyl in the winter to get a better colour match. Worked out a whole heap cheaper than replacing vinyl just because it is discoloured....
          • Prairiedawg
            • Jan 2013
            • 61
            • Saskatchewan
            Any pictures?
