Hi All,
SO I just put my boat in the water and my throttle is sticking quite bad. This started happening last year as well. It is completely fine when accelerating from neutral point. I then go back into neutral and the idle is way too high. (I often have to go back and push it by hand to go back to normal idle RPM). I am not sure where to start to fix this. I have tried adjustments on the back before the point of the servo wheel cable. Is is a stretched cable, maybe broken cable. What are your thoughts.
Any input is greatly appreciated.
Thanks Guys
Thanks Guys
