2002 Super Sport - Paddle wheel, but no Perfect Pass
  • crc203
    • 23
    • Alabama
    • 2002 Super Sport 2003 Ski Nautique 196 - Sold
    I've had the boat about a month, without perfect pass. I noticed it does have the paddle wheel on the bottom, trying to figure out what it might be used for.
    Thanks.
  • xlair
    • 694
    • Wisconsin
    Speedo probably, especially if you have the Faria gauges.
    2001 Pro Air Nautique
    • crc203
      • 23
      • Alabama
      It had the digital gauges that have been replaced. It does have the two tubes on the back ( I forget what they're called) that I assume are for the speedo.
      • jguanciale
        • Aug 2009
        • 34
        • Bullhead City, AZ
        • 1982 Ski Supreme 1992 Ski Supreme 1996 Ski Nautique 2002 Ski Nautique
        Pitot
        • Chexi
          • Apr 2025
          • 2119
          • Austin
          • 2000 SAN
          The pitot tubes were for the digital gauges. When they replaced them with the analog faria gauges, they do not work with the pitot tubes, and used the paddlewheel. This was correct. You should be able to use that same paddlewheel for PP if you want to. Just call Nautiqueparts.com and tell them what you have (the Faria replacement gauges with paddlewheel). There is a special cable you would need to tie the PP to that paddlewheel and still allow your speedo to work.
          Now
          2000 SAN
          Previously
          1999 Air Nautique
          1996 Tige Pre-2000
          • crc203
            • 23
            • Alabama
            Thanks a lot!
            • ski4evr
              • May 2010
              • 613
              • Bowling Green, KY
              • 2005 SV 211
              Or you could go stargazer and use gps if you aren't running a river with current. Don't have to touch existing spedometer setup.
              2005 SV-211
              • crc203
                • 23
                • Alabama
                I'll be putting in PP as soon as I save up the $$$. I'll probably go with the stargazer.
