The above pic was taken tonight when I noticed pretty significant scratches along my hull that line up with bunkers and are the same width. I had not noticed any wearing with the carpet, but plan to inspect it more when the boat is launched in the am. Ideas out there for buffing out my hull once the carpet is re done? what is the best method to go about replacing the carpet? Any links to recommended products or how to videos?? Thanks!
Don
- Jun 2008
- 2080
- Flowery Branch GA Lake Lanier
- 2008 210 SANTE 67 Correct Craft Mustang
When you power load, unload the boat you stir up sand ,dirt and small rocks some end up on the bunks. When you shallow load the boat you are driving up on gritty carpet and scratching the gel. The cure is to always put the trailer in deep and float the boat almost to the bow stop. Not only does it prevent the scratching it will also increase the life of the bunk carpet.
Every boat I've ever had.
It's not just because of power loading...it is mainly because of dirt/grit in your bunks. Dirt/grit gets there with the trailer just sitting in the (often dirt or gravel) parking lot while we're out on the lake.
I try to ignore it, lol.Previous boats:
2015 G23
2008 SAN 210
2002 XStar
1995 Sport Nautique
Anyone know if it can be buffed out? I have a black hull and looks terrible...to me anyway. I just got the boat so done by previous owner but thought maybe it was the carpet. One thing that I have always done with my other boats is back the trailer so all the bunks are underwater, then pull it up to where I want to load. I did this thinking maybe it would make the boat slide on better but maybe good for cleaning the bunks too.2006 Air Nautique 226
Originally posted by BlkCrkNautique View PostAnyone know if it can be buffed out?
Originally posted by xrichard View PostIt's not just because of power loading...it is mainly because of dirt/grit in your bunks.
On both my colored hulls, float them on only and they do not get scratched, kind of a PITA but so is wet sanding the scratches off regularly.
Originally posted by BlkCrkNautique View PostAnyone know if it can be buffed out? I have a black hull and looks terrible...to me anyway. I just got the boat so done by previous owner but thought maybe it was the carpet. One thing that I have always done with my other boats is back the trailer so all the bunks are underwater, then pull it up to where I want to load. I did this thinking maybe it would make the boat slide on better but maybe good for cleaning the bunks too.
