V-drive fluid blue?
  • mike32
    • Apr 2012
    • 52
    • lancaster ohio
    • 92 ski 02 super air
    V-drive fluid blue?
    Changed my vdrive fluid for the first time and it has a blue tint to it. Is this some type of synthetic fluid? Should I use a synthetic fluid? I believe it just calls for a 30 weight.
  • Jono
    • May 2010
    • 85
    • 1996 SuperSport
    Have the kids been playing with crayons in the boat?
    • 2001SAN
      • Apr 2012
      • 203
      • Ireland
      • 2001 Super Air Nautique 210, 1989 Fairline Corniche 31
      walter v drive? if so yes. straight 30.
      • AirTool
        • Sep 2007
        • 4049
        • Katy, Texas
        The only lube I've seen blue is the transfer case fluid for my 99 Tahoe. It is a delicious looking fluid. Like the label should be Barq's, Fanta, or Nehi.
        • mike32
          • Apr 2012
          • 52
          • lancaster ohio
          This isn't straight blue but it has a blue tint. Could it be an additive.
            What year boat,and Walters, or PCM V-drive?
            Reality is the V-drive has only about 5 bearings, and two gears in it. The oil used is really not that critical. That being said, use what the service manual recommends.
            • mike32
              • Apr 2012
              • 52
              • lancaster ohio
              2002 San. I think it is a Walters .
              • AirTool
                • Sep 2007
                • 4049
                • Katy, Texas
                maybe its a royal purple product.
                  I could be wrong on this, but I think Walters also suggested a gear lube for the V-drive, instead of 30 W motor oil.
                  • AirTool
                    • Sep 2007
                    • 4049
                    • Katy, Texas
                    I think you may be correct and a some of the gear lubes are colored (maybe only the syn lubes). Gear lubes have the EP (extreme pressure) resistance made for getting smashed between gears. Motor oils are not designed for that. Motor oils are designed for hydrodynamic bearings and lubricating piston rings (which behave similarly)
                    One thing is that detergent (HD) motor oils may foam in those gearboxes. That oil might need to be Non-Detergent (ND). This topic needs a bit of research.
