220 tower measurement
  • 1955 classic
    • Apr 2013
    • 39
    • New Zealand
    hi all
    getting a bimini made and boat is a few hours drive away and forgot a size, and also getting carpet made and i forgot a measurement. I need a measurement on a 2006 220 with a FCT3 tower(has the 3 flat bars on top)
    the measurement i need is the outside width of the rear upper legs, where upper tower meets the hoops which fix to the hull. basically where the big thumbscrew is for pulling apart the tower(or the inside measurement and i will add the tube thickness)
    also please a measurement down by the carpet, from the back engine fibreglass bulkhead (behind/below the flip seat) up to the right hand side walkway divider, which divides the drivers foot area from the walk thru.
    any help would be appreciated to save me driving 4 hours each way in next day or so
    thanks all
  • 1955 classic
    • Apr 2013
    • 39
    • New Zealand
    oops should have said it is an fct2 tower, the standard tower, not the fct3
