exhaust manifolds PCM 5.7
  • laurie8888
    • Dec 2011
    • 162
    • dubai
    • nautique 206 and 200
    This may be a stupid question, however which ports does the water flow through the manifold.
    I drained exhaust manifold, removed Riser for inspection and there is one large hole in center partially internally corroded, I guess water flows through this into the matching exhaust manifold large hole.
    Then also there are 4 thin slots on either side of manifold and riser, presume these are for gases and should have black carbon inside instead of rust....and should not fill with water ....Am i right?
  • AirTool
    • 4049
    • Katy, Texas
    The water is on the outside....else the surface of the manifold would be EXTREMELY hot. When the gaskets leak...they leave a rust trail down the outside.
    Plus a lot more cross sectional area is needed for the exhaust than the water.
    Also note one end of the outside has your water hose and the other end has a drain plug.
    http://www.submarineboat.com/images/..._lost_foam.jpg
    • laurie8888
      • Dec 2011
      • 162
      • dubai
      Thanks Airtool thats what I thought
      However when I sprayed some water into the Drain hole on the outside of the exhaust manifold im pretty sure some water shot up through the large hole in the middle....am i missing something here? how could this happen if they are seperate chambers
      • AirTool
        • 4049
        • Katy, Texas
        That doesn't sound good.
        • laurie8888
          • Dec 2011
          • 162
          • dubai
          After this I replaced the Riser gasket and put back together
          I have started the engine a few times and revved up to 3500 RPM, No problems encountered, also oil is normal viscocity on touch and no visual discoloration> temp 162 max.
          I only sparayed water in where water was coming out (drain holes)
          Manifolds are only 12 mths old. maybe I was seeing things!
          • AirTool
            • 4049
            • Katy, Texas
            Probably so.
