2008 210...When I charge the batteries i always set battery switch to 0 so no power goes to the system thinking it could cause a problem. usually i am in the boat wiping it down and i want to listen to the radio without running the battery down. so that is my question: Can i use battery charger with battery switch NOT on 0 and have accessories on? I have no idea. if charger says 10 amp and battery is like 600 amps then I would think no big deal, but I am unsure.
In a car i guess you could battery charge and listen to the radio so why not a boat? probably was a dumb question, huh?
