help my buddy get his engine right...
  • gride
    • Jun 2007
    • 1441
    • War Eagle
    • 05' 210 team
    i think i may have posted this question before, but here goes. so my buddy now has the $$ to get his boat working again. 2005 210 w ex330 closed cooled. he asked me if he should get a brand new engine(i' assuming it would have to be the ex343; which could cause some issues?). My answer is a jasper marine engine. Does anybody know what the block # and head # is? i think they told him they needed that information. Or, should he just have his current engine rebuilt? thanks for the info.
  • s_kelley2000
    • 1575
    • Fort Meadow Recevoir
    • Mass
    What happened to the engine, cracked block?
    Shawn
    2012 Blue Metal Flake SAN 230
    • shawndoggy
      • Aug 2011
      • 151
      • Reno
      • MB Sports TWB 23
      the 330 and the 343 are the same gm marine long blog. Just the bolt ons (manifolds, cats, alternator, etc) and tune are different. Any old GM long block will work fine.
      I'd order up one of these: http://www.michiganmotorz.com/350ci-...ent-p-109.html
      • gride
        • Jun 2007
        • 1441
        • War Eagle
        • 05' 210 team
        i'm no mechanic, but i think brackish h20 got into the engine when one of the risers was leaking. it's seized up. the info jasper needs that i don't technically have is really just rotation. i know it's roller not flat tappet, i know it's a 2005 350 cu in, etc. jasper seems to have a good deal after talking to them. i just figured the 343 wouldn't work because of the drive by wire throttle? either way it's definitely not going to be a new engine after checking prices.
        • s_kelley2000
          • 1575
          • Mass
          It is a standard rotation motor. There are probably a few exceptions but for the most part I think 88 was the last year that CC used reverse rotation motors. They unveiled the 1:1.23 transmission in 89 which allowed them to use standard rotation motors and reverse the rotation of the prop through the reduction transmission so they could still run RH props.
          Shawn
          • shawndoggy
            • Aug 2011
            • 151
            • Reno
            • MB Sports TWB 23
            That long block that I linked to is the exact same thing PCM would start with when creating either the ex330 or ex343.
            or buy the same thing here for a little more money: http://www.skidim.com/prodinfo.asp?number=RB001005H
            • mike32
              • Apr 2012
              • 52
              • lancaster ohio
              • 92 ski 02 super air
              So if this is true, is the apex the same block and heads? What is the difference?
