Knock sensor
  • sc8tt
    • Jun 2012
    • 111
    • smith mountain lake virginia
    • 2005 226 TEAM
    Knock sensor
    Last year I read a post that knock sensors needed to be installed at a very specific lb. of torque. I can't find it now.
    Bought my boat last year and during the test drive the knock sensor was not on. When I got it home, low octane fuel was put in it and the knock sensor came on.
    I assumed it was just the fuel. Several people said once the fuel was completely out, the sensor would simply go off. Never happened. So this year I took it to my local dealer and had the sensor reset. First time out... Sensor came back on. Definitely not the fuel.
    Please help.
    Could it be the torque thing I mentioned above? Any other ideas?
    2005 226 TEAM
  • sc8tt
    • Jun 2012
    • 111
    • 2005 226 TEAM
    Just to add a little more info, it has never limped or sounded. Just taken the function of one of my gauges.
    2005 226 TEAM
    • AirTool
      • 4049
      • Katy, Texas
      Did you apply any thread sealant or Teflon tape to the threads?
      • sc8tt
        • Jun 2012
        • 111
        • 2005 226 TEAM
        No, but I will. Any info on the torque?
        2005 226 TEAM
        • AirTool
          • 4049
          • Katy, Texas
          Originally posted by sc8tt View Post
          No, but I will.
          No - don't. It can block the electrical circuit. The sensor needs to be grounded.
          I'd have to look it up in my Tahoe book. Tonight. If you don't get it today, send me a PM around 7 tonight.
          • sc8tt
            • Jun 2012
            • 111
            • 2005 226 TEAM
            Will do. I have tomorrow off and would like to work on this. Thank you for your help.
            2005 226 TEAM
            • slob02
              • Sep 2003
              • 333
              I had to replace my knock sensor. I guess they can just go bad. Had the tech bring out his laptop and reset it and it was all good.
              2008 Super Air 210 Team
              2004 AIR 206 Team
              1997 Ski Nautique 196
              1993 Ski Nautique SNOB
              • sc8tt
                • Jun 2012
                • 111
                • 2005 226 TEAM
                Did you have similar issues to mine?? And a new sensor fixed it?
                2005 226 TEAM
                • AirTool
                  • 4049
                  • Katy, Texas
                  From my PCM manual
                  5.7L = 15-22 N•m (11-16 lb ft).
                  6.0L = 20 N•m (15 lb ft).
                  • frozone
                    • Aug 2009
                    • 25
                    • SLC, Utah
                    Is there any throttle sequence that will reset the engine codes or is the only way to take it to the dealer. I got the knock sensor see dealer message for the first time in 5 years. I've gone ahead and replaced the knock sensor, torqued to spec, and checked my wiring.
                    I'd really like to be able to reset the code without dragging the boat to the dealer, so that I can determine if I've fixed the problem or have bigger issues.
                    • slob02
                      • Sep 2003
                      • 333
                      There is a way, but I do not remember. Vince at discountinboard marine had told me once. Sorry.......I can't find it in any old e-mails!!
                      2004 AIR 206 Team
