Where is the blower motor in a 2006 SANTE
  • jkallen21
    • Jan 2013
    • 399
    • United States
    • 2006 Super Air 220
    I may need to replace the blower in my 2006 SANTE, but I need to find it in order to replace it! I can't seem to locate it - and I can't follow the noise because it's apparently dead - or stuck. If I can find it, I can fix it
    Thanks for any location assistance
  • s_kelley2000
    • 1575
    • Fort Meadow Recevoir
    • Mass
    If it is the same location as a 99 then it is down low near the rear of the boat on the starboard side. You will probably have to remove the divider and maybe a ballast tank to get to it. Look for the black corrugated hose that exits the rear of the boat and follow that down to the bilge and you should see it.
    Shawn
    2012 Blue Metal Flake SAN 230
    • NautiqueOasis
      • Oct 2005
      • 142
      • Dayton, OH
      • '13 200V Sport; '05 SV211; '97, '90 , '85 & '79 Sk
      as s_kelley describes the blower on our '05 211 was down low at the rear of the boat on the starboard side. I did have to remove divider and ballast tank to get to mine; quite a PITA on a 211.
      '13 200V Sport Nautique
      '05 SV211 Nautique
      '97 Ski Nautique
      '90 Ski Nautique
      '85 Ski Nautique
      '79 Ski Nautique
      • Desert surfer
        • Apr 2015
        • 1
        • AZ
        • 2006 SV 211 team Edition
        Once you found the blower, hoe difficult was it to replace?
        • NautiqueOasis
          • Oct 2005
          • 142
          • Dayton, OH
          Once the ballast tank was out and I had a little room to work with, I was able to replace the blower without any issue. Just a pain to get to it
          '05 SV211 Nautique
          '97 Ski Nautique
          '90 Ski Nautique
          '85 Ski Nautique
          '79 Ski Nautique
          • s_kelley2000
            • 1575
            • Mass
            Yes, very easy to replace. A couple screws for the hold down bracket, swap the wiring and the blower hose is held on with zip ties. If your hose is getting dry and starting to crack then this is a good time to replace that as well.
            Shawn
