Greetings,
I was checking all my fluid levels and noticed the Transmission was down slightly. I followed the procedure in the manual to get the motor up to temp and run the boat and then shift into gear, neutral, reserves and then measure from the dip stick. The manual is a little confusing on the process for the different transmissions listed. I checked on the name plate at it read " 1:1.050 ratio" on the tag. So my boat is a 2010 210, and I'm not sure if ti's the PCM Power Plus or just PCM. Any help would be appreciated. I have a fluid extractor and can get the transmission fluid as well, but what PCM recommends would be helpful, or if another fourm member has any insight.
Thanks,
Mike
Thanks,
Mike
