Hi, I am looking at buying a SAN, with GT-40, has 240 hrs on it, but i need to know of any special problems to look out for. I have an older nautique so have knowledge of the basic checks etc, but any pointers will be greatly appreciated, cheers.
RE: Buying a 2000 SAN
Basis checks; engine compression, transmission, ballast pumps, shaft allignement. Extra check; the digital gauges are a weak point of the 2000-2002 Nautiques. Check if they are replaced and if they all work correctly.230 with ZR6 running on propane
Laptom is exactly right. Those digital gauges were a cool idea, but they just didn't work out too well. There is a ton of information on them HERE. The GT-40 engine is a proven performer though!I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Adding to the above, each time the digital guages are
replaced, the hour meter goes to zero. I'd ask for service
records so that you can confirm it really only has 240 hours.
An Example. I have an 01 SAN. Currently says 120 hours.
Actually has about 350 hours (three guage replacements, Luckily
lifetime warranty on the guages).
Also, they have had some problems with the V Drive leaking.
You can look in the bildge below the v drive for signs of leaking.
I've had the gasket on mine replaced, and seems to be no further
problem. One poster on this site has had the repair five times.
Other than that, routine maintenance, and I've had no problems
with this boat.
BKH2001 Super Air
