Question about voltage at coil on 1993 PCM 351 Windsor
  • parham
    • Jun 2013
    • 2
    • NC
    • 1994 Ski Nautique
    I am having a problem starting the motor when the voltage at the coil is less than 12 V. We have 12.8 V off of the battery, but read less than 12 V at the coil. The voltage is inconsistent as when 12V is present the motor starts instantly, but when less than 12V at the coil engine will not start. Could this be a coil problem or is it a voltage supply to the coil?
  • parham
    • Jun 2013
    • 2
    • NC
    • 1994 Ski Nautique
    bump
    • jbach
      • Aug 2012
      • 187
      • the state, not the jelly
      • 1999 SAN
      did that boat come with pro-tec ignition and changed over? typically a coil will either work or it won't. i would ask this over on correctcraftfan.com .
