Look in the manual for KDW settings, if I remember rightly adjusting this determines how aggressive the servo makes adjustments to the speed. Think factory setting is 80kdw. Heavier ballasted boats may need a higher kdw setting. Maximunm is 200.
Also check your Nn setting. This is to do with paddle wheel filter. (if you have a paddle wheel) If your speed is varying then I think reducing your Nn setting should tighten it up. Can't remember exactly but it does tell you in the manual.
You can download the manual from perfect pass web site.
Hope this helps
Sent from my HTC One using Tapatalk 2
Current
2001 SAN 210, GT40
Previous
1994 Mastercraft Pro Star 190
