low pressure fuel pump flow
  • johnboyy7
    • Oct 2009
    • 409
    • houston
    low pressure fuel pump went out. trying to figure out what the flow rate is so i can buy one from oreilys.
    04 pcm 343
    04 SANTE 210
    89 SPORT
  • Rick
    • Mar 2004
    • 1250
    • San Diego, Ca
    Be careful buying an automotive pump for marine applications. If the diaphragm fails on an automotive pump the gas leaks out as little vent hole onto the ground. In a boat it leaks out into the bilge. BOOM! There are 5 things you want to make sure are rated for marine applications. The carburetor, alternator, fuel pump, starter, and starter solenoid. All are sealed to prevent gas leaking into the bilge or an open spark in the bilge. They are sealed which is why they are more expensive.
    Nautiqueless in San Diego
    • AirTool
      • 4049
      • Katy, Texas
      04 pcm 343
      COME ON MAN....what are you thinking?
      Use code PND for the discount. Order now it might ship today.
      http://www.nautiqueparts.com/fuelpum...ricsupply.aspx
      • johnboyy7
        • Oct 2009
        • 409
        • houston
        thinking less than half the price for samething.
        04 SANTE 210
        89 SPORT
        • Rick
          • Mar 2004
          • 1250
          • San Diego, Ca
          It's not the same. You will see a little hole on the top of the automotive pump. That is where the explosion will start.
          • AirTool
            • 4049
            • Katy, Texas
            Its probably not the same thing and you'll probably have to cut the connector off and splice the wires. Inlet might not match either.
            If you are dead set on it, go to Carter or Airtex site and browse the buyers guide.
            I see much more risk and PITA than savings here.
            • johnboyy7
              • Oct 2009
              • 409
              • houston
              i was hoping to get one before the weekend.
              i read that its for marine use. of course that does not mean its prolly sealed.
              04 SANTE 210
              89 SPORT
              • Connor
                • Aug 2012
                • 78
                • Austin, Texas
                Are you positive the fuel pump is out? I had the same issue, ordered a fuel pump but decided to check the relays before I installed the pump. Changing the relays fixed it right up and I had o ship the pump back, etc... Just a thought
                • pSchwade
                  • May 2012
                  • 127
                  • Reno
                  • 07' 220 SANTE
                  just make sure you get a marine relay. I hear that its ok to use an automotive one to diagnose but they dont have the mounting bracket - so I wouldnt recommend it out on the water.
                  • johnboyy7
                    • Oct 2009
                    • 409
                    • houston
                    the pump comes on but there is no suction. pump will be here monday.
                    04 SANTE 210
                    89 SPORT
