GT-40 Q on Acceleration vs. Cruise Mode
  • pdxCC
    • Aug 2009
    • 143
    • Portland, Oregon
    • Current -> 01' Air Nautique Previous - 93' Ski Nautique
    Quick Q. Does the GT-40 have an acceleration and "cruise" mode like the older carb'd Pro-Tec motors. When i finally added ballast over stock on my 01' Air it would stop accelerating hard at around 14-15mph and i would have to give it more gas to get to 22-mph and have PP engage.
    Not a problem, just like to know how everything works.
    Cheers!
    Brett
    ____________________________________________
    Current Boat --> 01' Air Nautique (April 12' to current!)
    Previous Boat - 93\' Ski Nautique Closed Bow ( Sept' 09 to March 12')
    Brett, I think this is a problem with Perfect Pass. I believe Perfect Pass is designed to back off the throttle, as you approach the set speed, to avoid overshooting the speed. With a slalom skier, a light ski boat accelerates harder, and needs the throttle backed off sooner
    Remember, Perfect Pass was designed for a slalom skier, with a light boat, and a relatively big engine, running close to the RPM where the engine is most efficient. When you wake board, you run the engine below an optimum speed, with a heavy load. You can learn the characteristics of the perfect pass in your boat, and you can work the throttle a little more to assist the Perfect Pass to settle in to the desired speed.
