A submerged log damaged the prop shaft, prop and rudder. Strut appeared ok. The prop shaft, prop and rudder were replaced. Unless it is my imagination, the wake is now worse. Two questions;
1.How can I confirm everything is properly aligned?
2.What are the specs for the subject equipment including the propeller shaft diameter and angle?
It's getting cold, so I am going to pull the boat and would like to satisfy myself that the correct equipment is installed and aligned.
