Guys
When changing element inside FCC Canister the manual says'
' disconnect the fuel supply line from the LPFP'
WHERE IS THE FUEL SUPPLY LINE....I only have the elec connector attached to the LPFP
I HAVE RUBBER HOSE connected to top of canister...is this the fuel supply line?
Also do I remove any of the two hard piped fuel lines (fuel in and return) coming into the top of the canister
See picture attached of my set up
thanks for help
thanks for help
