I have an 06 SANTE but I feel like most of the experts here already know that since I have asked so many questions
I had a bad oil sending unit that caused a leak. Prior to replacing it, the boat was consuming a lot of oil as I limped it to the ramp. No alarm, pressure was reading 40-60, and no check engine light.
2 weeks at the dealer, they isolated it to the sending unit. They said there were 2 parts to the unit, one controlled the check engine light, the other controlled the gauge. They replaced both. I got it back and took her for a ride. Immediately I see the check engine light on solid, alarm going off, gauge reading zero. Back to the dealer - who says "sorry, we crossed the check engine and gauge wires. 45 mins later they fixed that.
All seemed ok for most of the day. Then I started randomly hearing the alarm and pressure drops to zero when the alarm goes off. The check engine light does NOT come on. The boat has oil - checked it multiple times.
When the pressure drops to zero, I can give it more throttle or less throttle and the gauge returns to normal and no alarm. What's going in here? I have theories but don't want to lead the witness
specific questions:
1. Why alarm and no light?
2. Why pressure drops to zero and reruns when messing with the throttle?
3. What the heck is going on?
thanks guys!
specific questions:
thanks guys!
to remove the pickup tube to get the pump off. It only took a second to clear the blockage and clean it up but for piece of mind I had a new one on hand and installed it.
