Hi everyone,
First off, I have read a lot on this and other boards to try to diagnose my issue (so thank you for that so far). My 1997 Ski Nautique GT-40 starts to die or sputter out on me after it has run for between 10 and 20 minutes. I can be running along fine, and then it just starts to die and I if I let off on the throttle, I can most of the time keep it running, and then take off again where it might run fine again for 20 minutes or longer. It is not a limp mode sort of thing, as I have seen that in the past with a bad pressure switch.
Because I also have a 1996 Nautique with the same engine, I have swapped out the
1) Entire FCC (with a new filter), and I think the hose is good since it came from a good running boat and looked ok
2) Low pressure pump
3) Oil pressure switch (and I believe the larger round one next to it that I think gives you the analog readout on the dash)
4) Both fuel pump relays (I installed 2 new ones)
5) Some sort of temp sender (located on the driver side of the engine on top of the block which is on top of the brass fitting that sends water to my heater and has 2 wired connected to it)
6) Checked out the 90 deg fitting/filter coming out of the tank
7) The engine computer (whatever it is called). I took the one out of my 96 and installed it in my 97 with no change
In addition to changing these items out one at a time I used a pressure gauge to measure my fuel pressure while running the boat on the water. When the boat was running fine, the fuel pressure was rock solid, and just before it would start to sputter or stall, I would see the pressure become somewhat erratic. It would happen about a second or 2 after seeing the gauge start to flutter.
This has been an ongoing issue since the middle of last summer for me, and it runs great for short outings, but when it gets a little longer I start having issues.
About the only sensors that I have not swapped out are the 2 located on the passenger side of the engine, and will do those unless any of you have any other ideas. I do have a multimeter, but was not sure where to try to measure resistance or voltage to troubleshoot things.
Thank you for your time!!!!
Kent
Kent
