Bad battery connection
  • wakebrd21
    • Jun 2013
    • 61
    • Riverview, FL
    • 97 Sport
    I'm trying to find a solution to a problem on my 97 Sport.
    I had been having problems starting the boat and noticed the connection to the battery would spark and start to smoke. I put on a new metal ring that connects to the battery and its worked like a gem for a few trips out but the last time out I noticed the engine was taking a little longer to turn over and I could hear the battery sparking again even with the bow cushions in and the battery compartment closed. Any suggestions??
  • wakebrd21
    • Jun 2013
    • 61
    • Riverview, FL
    • 97 Sport
    Bump. Any help would be greatly appreciated.
    • HS
      • Oct 2007
      • 1333
      • Sammamish, WA
      • 2010 SANTE 210 (Sold)
      Check to see if the ground cable connection (away from the battery) is loose?
      • jasper
        • Feb 2005
        • 195
        If the battery was smoking (vs the connection to the battery) your battery is definitely bad. I would have the battery checked out anyway. I've had a new battery that would barely get the engine started. That battery would not take a charge and began smoking. Replaced with another battery and solved the problem.
        • wakebrd21
          • Jun 2013
          • 61
          • Riverview, FL
          • 97 Sport
          Where exactly does the ground cable go away from the battery?
          • wakebrd21
            • Jun 2013
            • 61
            • Riverview, FL
            • 97 Sport
            So this caused me some pain today. Started fine but first time I turned the boat off it wouldn't start again. I took both connectors off and cleaned them. Started perfect but when I went to put the battery back in the compartment the engine died. I went and jiggled the wires and it started again.
            The engine cut off a few more times while pulling tubers. Seemed to happen right after I hit a wake, so the wires probably moved a bit. Should I be looking to replace the battery wires??
            • wakebrd21
              • Jun 2013
              • 61
              • Riverview, FL
              • 97 Sport
              I looked for new battery cables on nautiqueparts.com and couldn't find anything.. Hmm
