Slight hesitation in the water
  • jkallen21
    • Jan 2013
    • 399
    • United States
    • 2006 Super Air 220
    I have a question that is difficult to describe. It could be nothing more than the fact that this is my first experience with an inboard. So here goes:
    While pulling some tubers, I can be cruising at around 15MPH and there will be this feeling that the boat is hesitating for about 1 second. This is not a fuel related hesitation. It's more like the prop is unable to push hard against the water for that 1 second if that makes any sense. There is nothing wrong with the prop that I can see. Then it's gone and I won't feel it again for a while.
    I know it's not much to go on, but thought I'd throw it up the pole and see.
  • Clibka
    • Dec 2012
    • 406
    • Illinois
    • 2021 G23 2012 210 SANTE (Previous)
    R u turning when pulling these tubers?
    First and Current - 2012 210 SANTE
    • robertsmcfarland
      • Oct 2004
      • 544
      • Hyco
      • 2014 g23 550
      cibka, ask the right question , also what model nautique do you have, this will also help with someone answering your question but 15 mph in my opinion, is real slow pulling tubers( make sure you only tell people you pull on windy ruff days) if not ,,you might not get a answer. but I feel your speed is the problem, you feel your prop cavitation, during your turns.
      2013 G23 super air
      2010 230 super air
      2009 220 super air
      2008 210 super air
      2005 210 super air
      2003 calabria pro air
      • jkallen21
        • Jan 2013
        • 399
        • United States
        I suppose it could be during turns. I will be more observant. I appreciate the pointer to Cavitation - Which I have now read up on. I will take note of which prop I have when I can get it out of the water. As far as the boat itself, it's a 2006 SANTE with a ZR6 engine. I have no reason to believe it's not a stock prop.
        • Clibka
          • Dec 2012
          • 406
          • Illinois
          Hey rob, were you telling me to ask the right question? or saying in the affirmative that I asked the correct question?
