Depth Sounder
  • super01
    • Jun 2009
    • 277
    • 2008 Super Air 230 2001 Super Air 210 (Sold)
    Depth Sounder
    I'm getting intermittent "----" (no signal) indication from the gauge on the depth sounder. I checked the plug on the gateway box, it appears to be secure. Anyone ever have the sending unit fail on them? Other places I should look in the system?
    2008 Super Air 230 ZR6
    2001 Super Air 210 GT-40 (Sold)
  • scottb7
    • Aug 2011
    • 2198
    • Carson City, Nevada
    Replaced mine last year. http://www.planetnautique.com/vb3/sh...roblem-and-Fix
    • jankedm
      • Oct 2010
      • 23
      • Spokane, WA
      • 2002 Nautique Super Sport
      I had intermittent issues with mine also. My transducer is mounted to the hull under the transmission. I topped off the pink RV type antifreeze that displaces the air under the transducer and have not had a problem since. It looked full, but must not have been.
      • Nordicron
        • Sep 2009
        • 557
        • Madison, WI
        "What'chu talkin' 'bout, Willis? Are you saying yours is mounted in a tank of somesort?
        • jankedm
          • Oct 2010
          • 23
          • Spokane, WA
          The transducer on mine sits inside a black housing that is glued/sealed to the hull. You fill the "ring" with RV anti-freeze or oil in some instances. Then the transducer screws onto that ring. Not sure what type you have.
